Trailer Brakes
The Italian Boy
I have the tow mode button on my dash and I have the tow package on the rear....I have the round connector I am going to tow with the T next weekend do i need to install a trailer brakes inside the cab? I Think I need to but Im just not sure. Im still pretty new to this so sorry.......I'll post a pic of my connector after lunch.
tc3driver
Does the trailer have an electronic braking system?
If so then yes you need the trailer brake module.
I'll let those with more experience what you need..
The Italian Boy
[quote name='tc3driver' post='128804' date='Jun 18 2008, 12:22 PM']Does the trailer have an electronic braking system?
I'll let those with more experience what you need..[/quote]
Its a 25' travel trailer I know we have a brake controller in the suburban so I will probably need one are they hard to install yourself or is it just plugging in a few wires, I can do just about anything else but messing with electrical stuff is not my specialty.....
tc3driver
[quote name='The Italian Boy' post='128805' date='Jun 18 2008, 11:07 AM']Its a 25' travel trailer I know we have a brake controller in the suburban so I will probably need one are they hard to install yourself or is it just plugging in a few wires, I can do just about anything else but messing with electrical stuff is not my specialty.....[/quote]
If you have the trailer brake harness that came with the tow package... it is a straight forward install.. wire up the brake controller to the module, and plug her in!
The Italian Boy
[quote name='tc3driver' post='128806' date='Jun 18 2008, 01:21 PM']If you have the trailer brake harness that came with the tow package... it is a straight forward install.. wire up the brake controller to the module, and plug her in![/quote]
where would I find the harness? do I have to pull off part of the dash? Has anyone done this with Photos?
terryu1
[quote name='The Italian Boy' post='128807' date='Jun 18 2008, 03:26 PM']where would I find the harness? do I have to pull off part of the dash? Has anyone done this with Photos?[/quote]
Harness is usually in glove box. Like they said just hook it up wire to wire to the controller you are going to use and the plug in is under the dash above the emergency brake. Easy to find Check out this link for instruction. http://www.randpcarriages.com/tech/nissanbrakecontrol.html
The Italian Boy
[quote name='terryu1' post='128810' date='Jun 18 2008, 03:13 PM']Harness is usually in glove box. Like they said just hook it up wire to wire to the controller you are going to use and the plug in is under the dash above the emergency brake. Easy to find Check out this link for instruction. http://www.randpcarriages.com/tech/nissanbrakecontrol.html[/quote]
Thanks I'm goign to head down to the trailer store later and check out controllers we have the digital prodigy in the Burb....
Go to your local rv store and buy the Prodigy brake controller and Nissan harnes for aprox
$114 combined. Plug and play from there just follow the Prodigy instructions after the isntalll...
Hold on while I find my install how-to.....
Sheesh, maybe I never did a how to on this. Cant find it... Oh well, here are some install pics of the Prodigy...
Tow wiring harness. Taped up under dash.... If you have tow package..
Any ?'s post here or pm me and I'll give ya my cell #.. <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/004.gif' class='bbc_emoticon' alt=':smt002' />
tc3driver
ok I am going to repost them from my server, tell me if it works.
I hope this helps... and kev, I am not doing this to plagiarize you, just trying to help a brotha out ;)
The Italian Boy
So I just went and looked in my truck.....the guy before me must have had a brake controller....there are two holes drilled where you would mount the unit and there is the white plug hanging down over by the E Brake that says electronic brake controller....I'll Let everyone know how my Install goes....
tc3driver
[quote name='The Italian Boy' post='128831' date='Jun 18 2008, 08:36 PM']So I plug the harness into the back of the Unit, then plug the harness into the Titan?
Thats it?
No stripping wires or anythng?[/quote]
If you buy that cable from an RV shop... apparently.
The Italian Boy
[quote name='tc3driver' post='128833' date='Jun 18 2008, 09:45 PM']If you buy that cable from an RV shop... apparently.[/quote]
Awsome I'll go by the shop tomorow.....
[quote name='tc3driver' post='128833' date='Jun 18 2008, 08:45 PM']If you buy that cable from an RV shop... apparently.[/quote]
Yep nissan harness plug and play. Thanks for the help bill. Wonder what is up with photobucket??!
