Replace Transmission Valvebody With Another One
alby
I want to replace my transmission valvebody with a different one. The valvebody I am replacing is reprogrammed with a Transgo shiftkit.
The replacement valvebody has no shiftkit.
Do you think I'll have problems with the installation?
Problems that I foresee:
1.) The Transgo shiftkit has, in addition to it, a bushing which is installed into the transmission case. For that, I can just use a puller to remove it.
2.) The replacement valvebody may not be compatible because it may have a different VIN # associated with it. Both valvebodies, however, are for a 2004 Nissan Titan SE (mid 2004-2008 RE5R05A Transmission.)
FYI:
a.) I've already done work with a Honda Odyssey, replacing a transmission there with a rebuilt one. No problem there. The van accepted it.
b.) I'm replacing the valvebody reprogrammed with the Transgo shiftkit to get a normal ride again. That valvebody works fine but I seldom race my truck.
