Article title: Rear differential oil change.
Category: Engine/Drivetrain
Date added: Sep 23 2006, 12:01 PM
Using a 3/8” ratchet remove top plug on differential cover. (remove top first to be sure you can get it out to facilitate refilling after you drain it)
Remove lower plug and drain. The lower plug has a magnet on it to grab loose metal particles that may accumulate in the differential oil.
<!--id1--><embed style="width:400px; height:326px;" id="VideoPlayback" type="application/x-shockwave-flash" src="http://video.google.com/googleplayer.swf?docid=-6529716311688460158&" > </embed><!--id2-->
Lower plug with “stuff” on it.
Stuff
Plugs. Use a thread sealer to ensure no leaks after you install the plugs. I used Permatex Thread sealant with TEFLON.
Torque plugs to 25 ft-lbs.
Fill with 75w-140 Synthetic oil ONLY
You are done. Total time for me 15 minutes.
