Leaf springs on rear of 2WD
Rick
I am new on the this site. I have a 2004 T I am taking lowering spring off to reinstall factory springs .My problem is when i put it in it apears to be to short one way & to long the other way to line up with front bolt hole . The spring is longer from center to eye on one end . which way does it go . Long to the rear or front. Thanks for any help
Welcome to the site!
You should take a couple of pictures to make it clearer what parts you're referring to. I'm sure someone here can answer that.
