I installed my Sirius satellite antenna the other day and took a few pics. These are just some pics of the antenna. I didn't take any pics of the receiver install yet. <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/004.gif' class='bbc_emoticon' alt=':smt004' />
First thing you need to do is remove the two plastic plugs from the headliner.
Once they are removed you will need an 8mm deep socket w/extension or a nut driver. Remove the two nuts up inside the holes. (one in each hole)
Now you can remove the third brake light from outside. It will be tight because of the gasket, but the light will come right out with a good tug. Don't tug too hard though, cuz you will have to unplug the wire still. <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/002.gif' class='bbc_emoticon' alt=':smt017' />
Now you can mount the antenna centered on the roof and run the wire down into the cab.
Once the antenna is mounted to your liking and the wire is in the cab you can reinstall the third brake light. The finished product should look like this. <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
Now you can run the wire up to the front. I just ran it along the headliner on the passenger side under the molding, down to the dash and then under the dash to the center console, or were ever you want it to go to.
