After my recent Stillen all-aluminum radiator install, I was looking around to try to find the recommended method to check the Titan automatic transmission levels. In case anyone wonders, the procedure for checking AT levels is not in the owners manual.
I found this procedure for checking AT transmission fluid level in the 2005 Titan Service Manual and I thought it might be useful to attach the page for the procedure below for anyone that does not own a copy of the Titan Service Manual. Since the 2004 Titan introduction, the truck and the transmission is largely unchanged, so it is my guess is that this procedure should work for all current Titans. But, I want to add a caveat here that as a Titan owner, it is your duty to check if your production year Titan has a different AT fluid level check procedure.
