COASTAL FLUID LUBRICANT HAND PUMP
Changing fluids on the front and rear differentials, transfer and most gear cases can be done easily by Titan owners.
The Coastal screw-on pump and included slip-on attachments will fit on most gallon and wide-mouth quart sized oil containers.
The pump dispenses 1 fluid ounce in each depression 'stroke" of the pump head.
The pump is made of durable ABS plastic, tough and reusable!<img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/023.gif' class='bbc_emoticon' alt=':smt003' />
MANUFACTURER:
The Coastal fluid lubricant hand pump is made by:
Coastal Unilube Inc.
A Subsidiary of the Coastal Corporation
P.O.Box 2048
West Memphis, AR. 72303
in: Taiwan-(ROC)
PART#: CPE 89996
PACKAGING:
The Coastal hand pump comes in a polyethylene packaged bag with a cardboard backer with instructions printed on it inside.
INSTRUCTIONS:
Pictures and installation tips are supplied as well as tubing components to fit gallon or quart sized wide mouth oil containers.
ESTIMATED INSTALLATION TIME: 3 Minutes.
INSTALLERS REQUIRED: ONE
COST: ~$3.48 from Advance Auto NOT INCLUDING SHIPPING
WARRANTY: Not listed with packaging/instructions.
OWNER TIPS:
I have pre-cut slip-on extensions for the pick-up/lift-tube and pump spout extension.
When seated in position the pick-up/lift tube extends 3" to the end of the angled cut tip.
When seated in position the slip-on pump extension extends 7" to the end of the angled cut tip.
Cutting the tips of the slip-on extension tubes at an angle assures efficient dispensing of fluids and helps prevent blockages of the hand fluid transfer process.
The 7" pump extension requires holding the oil container in hand verses pumping from on the ground.
The 7" pump extension also has less length of tubing to drain and clean when the oil transfer process is complete.
(Photos provided by honeykeeper)
Happy "home oil-changing" with your Coastal Hand Pump. <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/023.gif' class='bbc_emoticon' alt=':smt006' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt016' />
MANUFACTURER:
P.O.Box 2048
in: Taiwan-(ROC)
PART#: CPE 89996
PACKAGING:
INSTRUCTIONS:
OWNER TIPS:
