Article title: 04-07 REAR DIFFERENTIAL FLUID CAPACITY
Category: Lubricants/Fluids
Date added: Jan 4 2006, 07:32 AM
Article starter: honeykeeper
04-07 REAR DIFFERENTIAL FLUID CAPACITY WITH OEM ALUMINIUM FINNED COVER
Transmission Fluid/Oil, Differential Oil, Transfer Case oil:
Visually inspect for signs of leakage at specified intervals.
If towing a trailer, using a camper or car-top carrier, or driving on rough or muddy roads, replace the fluid/oil every 30,000 miles or 24 months.
OFF-ROAD and 4x4 Maintenance:
Check the differential(s) frequently when you drive off-road through deep sand, mud or water.
NISSAN PREMIUM MAINTENANCE AND SERVICE SCHEDULE:
3,700 miles or 3 months: Inspect differential oil.
7,500 miles or 6 months: Inspect differential oil.
11,250 miles or 9 months: Inspect differential oil.
15,000 miles or 12 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 15K PREMIUM.
18,750 miles or 15 months: Inspect differential oil.
22,500 miles or 18 months: Inspect differential oil.
26,250 miles or 21 months: Inspect differential oil.
30,000 miles or 24 months: REPLACE DIFFERENTIAL OIL.
SCHEDULE 1-2 MAINTENANCE INSPECT ONLY.
33,750 miles or 27 months: Inspect differential oil.
37,500 miles or 30 months: Inspect differential oil.
41.250 miles or 33 months: Inspect differential oil.
45,000 miles or 36 months: Inspect differential oil.
SHEDULE 1-2 MAINTENANCE SAME AS 45K PREMIUM.
48,750 miles or 39 months: Inspect differential oil.
52,500 miles or 42 months: Inspect differential oil.
56,250 miles or 45 months: Inspect differential oil.
60,000 miles or 48 months: REPLACE DIFFERENTIAL OIL.
63,750 miles or 51 months: Inspect differential oil.
67,500 miles or 54 months: Inspect differential oil.
71,250 miles or 57 months: Inspect differential oil.
75,000 miles or 60 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 75K PREMIUM.
78,750 miles or 63 months: Inspect differential oil.
82,5000 miles or 66 months: Inspect differential oil.
86,250 miles or 69 months: Inspect differential oil.
90,000 miles or 72 months: REPLACE DIFFERENTIAL OIL.
93,750 miles or 75 months: Inspect differential oil.
97,500 miles or 78 months: Inspect differential oil.
101,250 miles or 81 months: Inspect differential oil.
105,000 miles or 84 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 105K PREMIUM.
108,750 miles or 87 months: Inspect differential oil.
112,500 miles or 90 months: Inspect differential oil.
116,250 miles or 93 months: Inspect differential oil.
120,000 miles or 96 months: REPLACE DIFFERENTIAL OIL.
Steps and Tools Needed to Drain and Refill the Rear Differential Fluid (to be performed after warm-up):
1- Lower the spare tire to the ground to access the fill plug.
2- Remove the fill and drain plugs with a 3/8" break-away bar or socket wrench. Remove fill plug first to allow air to enter gear case before draining.
3- Reinstall Drain Plug after used fluid stops draining (reseal plug with red RTV high temperature sealant).
4- Refill differential with new 75-140W synthetic differential fluid.
5- Install Fill plug ( reseal plug with red RTV high temperature sealant).
6- Inspect front and side shaft seals for signs of leakage.
Happy "Differential Fluid Changing!" <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/023.gif' class='bbc_emoticon' alt=':smt023' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
I changed my 05 Titan's REAR differential fluid over the weekend. Of course it has the OEM Aluminium finned-cover.
The 05 manual that came with my Titan has no fluid volume listings for the rear or front differentials?
I backed the rear on some wood 6x6" blocks to get more fluid in.
It took 66 oz. or 4.125 pts. or 2.0625 qts.
68 ozs. would be 4.250 pts.
To my surprise I noticed the fluid looked very good, not too dark and not a single speck of metal was in it or on the drain plug....just a little "break-in silver" seating grease on the magnetic drain plug.
I even used a small micron mesh screen to dump it thru and couldn't find a speck of metal!!<img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
My Titan almost has 12,000 miles on it so I figured it was time to change the front and rear differential fluids.
How much fluid have you been putting in when you change the rear and front diffies.?
Does anyone do some figure eight's like suggested by PML and recheck/top up again??
I thought I could get more oil in there??....I guess If I drive then check the level quickly it won't all be settled to the bottom and I can get more in but should I???
Ohhhhhhh I put in the Amsoil SEVERE GEAR 75-140W and my Titan seems to really love it....especially at 60-80 MPH I think I'm noticing less RPM's than before??!! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/020.gif' class='bbc_emoticon' alt=':smt003' />
Retail is $12.55 and preferred customers pay $9.70/qt.!! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/041.gif' class='bbc_emoticon' alt=':smt041' />
Amsoil gear oil containers don't have a convenient fill-spout on them so I used a Coastal Pump to do the filling.
The Coastal hand pump screws directly on the oil bottle.
Well I'll do the front differential next and with the same type fluid as I used in the rear!!! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/020.gif' class='bbc_emoticon' alt=':smt020' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/cheers.gif' class='bbc_emoticon' alt=':smt023' />
