04-07 Front Differential Fluid Capacity (4x4 Only)
04-07 FRONT DIFFERENTIAL FLUID CAPACITY (4x4 ONLY)
Transmission Fluid/Oil, Differential Oil, Transfer Case oil:
Visually inspect for signs of leakage at specified intervals.
If towing a trailer, using a camper or car-top carrier, or driving on rough or muddy roads, replace the fluid/oil every 30,000 miles or 24 months.
OFF-ROAD and 4x4 Maintenance:
Check the differential(s) frequently when you drive off-road through deep sand, mud or water.
NISSAN PREMIUM MAINTENANCE AND SERVICE SCHEDULE:
3,700 miles or 3 months: Inspect differential oil.
7,500 miles or 6 months: Inspect differential oil.
11,250 miles or 9 months: Inspect differential oil.
15,000 miles or 12 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 15K PREMIUM.
18,750 miles or 15 months: Inspect differential oil.
22,500 miles or 18 months: Inspect differential oil.
26,250 miles or 21 months: Inspect differential oil.
30,000 miles or 24 months: REPLACE DIFFERENTIAL OIL.
SCHEDULE 1-2 MAINTENANCE INSPECT ONLY.
33,750 miles or 27 months: Inspect differential oil.
37,500 miles or 30 months: Inspect differential oil.
41.250 miles or 33 months: Inspect differential oil.
45,000 miles or 36 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 45K PREMIUM.
48,750 miles or 39 months: Inspect differential oil.
52,500 miles or 42 months: Inspect differential oil.
56,250 miles or 45 months: Inspect differential oil.
60,000 miles or 48 months: REPLACE DIFFERENTIAL OIL.
63,750 miles or 51 months: Inspect differential oil.
67,500 miles or 54 months: Inspect differential oil.
71,250 miles or 57 months: Inspect differential oil.
75,000 miles or 60 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 75K PREMIUM.
78,750 miles or 63 months: Inspect differential oil.
82,5000 miles or 66 months: Inspect differential oil.
86,250 miles or 69 months: Inspect differential oil.
90,000 miles or 72 months: REPLACE DIFFERENTIAL OIL.
93,750 miles or 75 months: Inspect differential oil.
97,500 miles or 78 months: Inspect differential oil.
101,250 miles or 81 months: Inspect differential oil.
105,000 miles or 84 months: Inspect differential oil.
SCHEDULE 1-2 MAINTENANCE SAME AS 105K PREMIUM.
108,750 miles or 87 months: Inspect differential oil.
112,500 miles or 90 months: Inspect differential oil.
116,250 miles or 93 months: Inspect differential oil.
120,000 miles or 96 months: REPLACE DIFFERENTIAL OIL.
Steps and Tools Needed to Drain and Refill the Front Differential Fluid (to be performed after warm-up):
1-
Remove the differential skid pan/plate to access the fill/drain plugs.
2- Remove the fill and drain plugs with a 3/8" break-away bar or socket wrench. Remove fill plug first to allow air to enter gear case before draining.
3- Reinstall Drain Plug after used fluid stops draining (reseal plug with red RTV high temperature sealant).
4-Fill differential with a Coastal Pump and with 75-90W synthetic differential fluid.
5- Install Fill plug ( reseal plug with red RTV high temperature sealant) after refilling the differential with new fluid.
6- Inspect side shaft seals for signs of leakage.
Happy "Differential Fluid Changing!" <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/023.gif' class='bbc_emoticon' alt=':smt023' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
I changed my 4x4 05 Titan's FRONT differential fluid over the weekend.
The 05 manual that came with my Titan has no fluid volume listings for the front or rear differentials?
I changed the fluid sitting on level ground. It took 58 ozs. sitting level.... which I calculate to be 3.625 pts. or 1.8125 qts.
To my surprise I noticed the OEM fluid looked very good, not too dark and not a single speck of metal was in it or on the magnetic drain plug....just a little "break-in silver" gear seating grease on the plug. The top fill plug is the same size and is magnetic also.
I also use a small micron mesh screen to dump/filter it thru and couldn't find a speck of metal!! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt020' />
My Titan almost has 12,000 miles on it so I figured it was time to change the front and rear differential fluids.
Amsoil gear oil containers don't have a convenient fill-spout on them so I used a Coastal Pump to do the filling.
The Coastal hand pump screws directly on the oil bottle.
Here's the link to the Coastal Fluid Pump :
http://www.titanspot.com/Titan/index.php?s...hl=coastal+pump
ss350z
For some reason, I can't find the Front Diff fluid Change Wiki, but am I correct in that you have to have some kind of pump ( ie Coastal Pump) to change the front diff fluid? Otherwise, it sounds like just removing the skid plate and both plugs.
I took a look under the truck yesterday, and it looks awfully tight.
[quote name='ss350z' post='146492' date='Apr 22 2009, 09:06 AM']For some reason, I can't find the Front Diff fluid Change Wiki, but am I correct in that you have to have some kind of pump ( ie Coastal Pump) to change the front diff fluid? Otherwise, it sounds like just removing the skid plate and both plugs.
I took a look under the truck yesterday, and it looks awfully tight.[/quote]
Correct and here's the link to the Coastal Fluid Pump :
