04-07 Engine Oil Capacity For All Titans
Article title: 04-07 ENGINE OIL CAPACITY FOR ALL TITANS
Category: Lubricants/Fluids
Date added: Jan 9 2006, 06:44 PM
Article starter: honeykeeper
The 05 owner service manual that came with my Titan lists the engine oil fluid capacity at:
6.50 (U.S. Measure) quarts with OEM oil filter change
6.25 (U.S. Measure) quarts without OEM filter change.
The specifications call for the replacement oil to have a rating of:
API Certification Mark *2*3
API grade SL
Energy Conserving *2*3
ILSAC grade GF-III *2*3
NOTE: *2*3 information in Titan manual.
The NISSAN SERVICE AND MAINTENANCE GUIDE that came with my Titan lists the following MAINTENANCE SERVICE SCHEDULE dates for changing the engine oil and filter:
PREMIUM MAINTENANCE: 3,750 miles or 3 Months
Shcedule 1 Maintenance: 3,750 miles or 3 Months
Schedule 2 Maintenance: 7,500 miles or 6 Months
Note: Use a 14 mm socket to remove the oil pan drain plug.
1-9-06 Engine Oil and Filter Removal and Replacement Data:
Miles logged at todays oil change on Titan: 12,377
Miles logged at last oil change: 8,425
Miles logged on last batch of oil: 3,952
Brand of engine oil used on last oil change: Mobil1 5-30W "SuperSyn" Synthetic
Brand of oil filter used on last oil change: NISSAN OEM #15208 9E000
Amount of engine oil removed/recovered at todays oil change: 6 qts. 4 ounzes.
Number of oil changes excluding today's oil change: 3
Oil Sample taken for used oil change sent to:
Oil Analyzers, Inc.
2206 Winter Street
Superior, Wisc., 54880
Tel. 715-395-0222 Fax. 715-395-0222
Sent by UPS on 1-10-06.
Cost: $22.50 with pre-paid shipping.
Brand of oil used on todays replacement change: Amsoil Series 2000 0-30W
Brand of oil filter on todays replacement change: Amsoil Ea013
Amount of oil added to engine at todays oil and filter replacment: 6.5 quarts.
6 quart mark on dipstick after engine crank and 3 minute run follwed by 30 minute cool down: ~ 1/8" above the lower mark.
6.5 quart mark on dip stick: ~5/8 distance between upper and lower marks.
6.5 quart mark on dipstick after engine crank and 3 minute run followed by 30 minute cool down: ~5/8 distance between upper and lower marks.
Comments on new oil:
1- First engine start-up @ 50°F ambient temperature results in oil pressure indicator slightly below 3/4 mark and settles to one needle mark above normal setting quickly. Previous 5-30W oil would spike oil pressure indicator to H at same start-up temperature.
2-At 58 MPH my Titan seems to have dropped 50-100 RPM's verses all other oils I've tried in the 04 and 05 Titan.
Tip on oil filling: Stand new empty oil bottles used upside down with cap on and in sun for 30-60 minutes.
One cap full of oil will remain in cap and can be added to engine for complete transfer.
Tip on oil recycling: I brought my used engine and front/rear differential oil to a local speed oil change shop.
They gladly accepted it for free as they have a heating system in the building that filters and burns the used oil in an efficient heating system.
Happy "Engine Oil and Filter Changing!" <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/006.gif' class='bbc_emoticon' alt=':smt023' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt001' />
