Lifted Titans with Big Tires - Post your MPG
I'm not interested in mini-lifts..I'm curious what people with a 4" - 6.5" lift and big tires (35s) on their 4x2 Titan are getting for MPG...
  • What size lift do you have?
  • What size tires/wheels are you running?
  • What was your city/hwy MPG before lift/tires?
  • What is your city/hwy MPG with lift/tires?
    • I'm considering adding:
      • CST 4" Spindle Lift
      • PRG 2.5" Front spacer (already on my truck)
      • Rear Bilstein shocks
      • CST Carrier bearing drop kit
      • 2" Rear Block
      • 2.5" Deaver pack
        • The above items will cost me around $1100...New tires will run another grand probably, so I'm looking at around $2000 to get the look I really want. It's quite a chunk of change, and if I decide to pull the trigger on this, I will end up keeping my Titan for a long time to enjoy the mod and spread the cost out a bit. I'll probably put on 35" tires on the stock 18" rims. I'm thinking about pulling the trigger for this lift in late Spring, probably sometime around May.
          I'll add new coilovers after the stock ones start crapping out on me.
I would say expect somewhere around 10-11 mpg with that setup
[Image: titan.jpg]
Mine varies from around 9-11 MPG. 6 1/2" lift with 35" A/T's with no tow gear.
[quote name='VShortt']Mine varies from around 9-11 MPG.  6 1/2" lift with 35" A/T's with no tow gear.[/quote]
Ditto.
[Image: Ramsig-vi.jpg][Image: Titansig-vi.jpg]
I dunno what I'm gettin with the 37's. But it ain't enough!
[quote name='QWIKWHIP'][quote name='VShortt']Mine varies from around 9-11 MPG.  6 1/2" lift with 35" A/T's with no tow gear.[/quote]
Ditto.[/quote]Not completely ditto. You're running M/T's.
I say go for the lift and such..I'm sure the MPG difference isnt that great..
[quote name='VShortt'][quote name='QWIKWHIP'][quote name='VShortt']Mine varies from around 9-11 MPG.  6 1/2" lift with 35" A/T's with no tow gear.[/quote]
Ditto.[/quote]Not completely ditto. You're running M/T's.[/quote]
lol, I should have been more clear. I was just Dittoing the mileage. lol <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt004' />
I know I'm only at 3" lift with 33's, but I'm getting about 11.5 mpg. I also have the BT gears like you do, so you will have my lower gear ratio, not the higher one like V and Q-dub.
I just got a Titan with a lift (not sure how high) and its doing about 9mpg, does a cover really help with gas mileage and are there any other tips to increase mileage on these beasts, I love the truck so far but its really hurtin my pocket!
If you guys wanna guess the lift go ahead !! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/001.gif' class='bbc_emoticon' alt=':-)' />
Attached Files Thumbnail(s)
rodytoon
welcome to the Spot. My ARE cover didnt help with mpg then again it weighs about 200 lbs.. I think this myth was busted on myth busters or was it driving without a tailgate... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/017.gif' class='bbc_emoticon' alt=':smt006' />
welcome to the Spot. My ARE cover didnt help with mpg then again it weighs about 200 lbs.. I think this myth was busted on myth busters or was it driving without a tailgate... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/017.gif' class='bbc_emoticon' alt=':-)' />
On mythbusters I think they were prooving the tailgate down makes better MPG myth... and I think they got better results with the tailgate off totally...if I remember right...or was it up?...lol
[Image: outrail1-1-1.jpg]
The 2nd Amendment... Washington didn't use his right to free speech to defeat the British, He shot them.
Happiness Is Beating Bama in Anything, Anytime, Anywhere
[Image: 83348.png]
04' Deep Water LE 4x4 CC Off-Road Big Tow, 09' PRO 4X Coilovers & Rear shocks, PRG Mini Kit 2" Front 1" Rear, PRG Adj. Swaybar endlinks, QX56 Swaybar Bushings, PRG Shackles, PRG Off Road Traction Bars, 35" Pro Comp Xtreme A/T's on Graphite OEM 18's, (2012) Pro 4x rear End, Austin E-Lock Mod, Mag Hytec Diff cover, Superchips Cortex, Blue Activetuning Grounding Kit, 6000K HID Lows, Silver Star High & Turns, 3000k DDM HID Fogs, Flowmaster 40, VOLANT GEN III CAI, Throttle Body Screen Mod, Custom Painted Relentless RPM Catch Can, UpRev 2 Deg. Timing Advance, Kenwood DNX514 HU, Sony Explode 4ch Amp, Cadence 6.5" Components, (2) 10" Subs, Vshortt Built Custom Box, Clarion APX-1300 400 watt Amp, Black Billet 9" Antenna, Billet Grill , (3) 8" Procomp 130 watt Off-Road Lights, (2) 55 watt Back-up Lights, Custom Painted Engine Cover V with matching CAI lid.
SEMPER FI
WAR EAGLE
well i know this is super old but i just thought i would add. i normally get between 10-12 city i have gotten up to 16.5 on the freeway before
What size lift do you have? apx 12ish
[*]What size tires/wheels are you running? BIG
[*]What was your city/hwy MPG before lift/tires? dont remember
[*]What is your city/hwy MPG with lift/tires? 10-16
[Image: gallery_1766_98_24165.jpg]
2005 4x4 6in Fab-tech suspension lift, 3inch performance accessories
body lift, flipped shackle mount, custom shackles making 3in lift,
08 coilover spring making 2-3in lift, 40 series flowmaster,
17x10 ultra rogue wheels, 38.5x15.50 super swamper radials,
ranch hand rear bumper, side running boards, hella lights.
Volant CAI & SuperChips Cortex
DanielK
#14
I get 12 around town up to 18 hwy........ Stock LTXtires, mini lift
#15
more like baby lift KEV!! hahaha lol
DanielK
