Modifying differential
Bought a 2006 Titan SE and found out after that it has an open differential. The slip is only offered in the LE on 4x2 models according to the dealer. Since I don't really want to go trade my truck in on an LE is there a kit available to convert it to a slip differential? I have tried seating the Internet for it and haven't had good results. Any solutions?
Detroit Truetrac probably what you looking for
Up Rev tuned - 305.5 RWHP, 370.4 ft/lbs tq Detroit Truetrac.
[Image: sig3.jpg]
Titan part numbers
Not very familiar with differential work would a Detroit lock be all that is needed? Does that mean the axle is set up from factory to be converted if desired?
Unless you're going rock climbing or four wheeling, you probably don't want/need a locker. What you should look at is the True-Trac differential that a lot of members have, including me, and is virtually a plug n' play swap. Check out the following video to see the True-Ttac in action:
http://www.youtube.com/watch?v=-5tf65Z0f30
EDIT: There is a PART 2 Video as well.
http://www.youtube.com/watch?v=C0menFmqW...re=related
DISCLAIMER: If you find a posting or message from me offensive, inappropriate, or disruptive, please ignore it. If you don't know how to ignore a posting, complain to me and I will be only too happy to demonstrate...
Hung like Einstein and smart as a horse!
THIS SPACE FOR RENT.
[Image: StretchTitancopy.jpg]
[quote name='baseballfanz' timestamp='1302883597' post='160623']
Agreed....Capt' true trac should reply any minute now..lmao
[Image: outrail1-1-1.jpg]
The 2nd Amendment... Washington didn't use his right to free speech to defeat the British, He shot them.
Happiness Is Beating Bama in Anything, Anytime, Anywhere
[Image: 83348.png]
04' Deep Water LE 4x4 CC Off-Road Big Tow, 09' PRO 4X Coilovers & Rear shocks, PRG Mini Kit 2" Front 1" Rear, PRG Adj. Swaybar endlinks, QX56 Swaybar Bushings, PRG Shackles, PRG Off Road Traction Bars, 35" Pro Comp Xtreme A/T's on Graphite OEM 18's, (2012) Pro 4x rear End, Austin E-Lock Mod, Mag Hytec Diff cover, Superchips Cortex, Blue Activetuning Grounding Kit, 6000K HID Lows, Silver Star High & Turns, 3000k DDM HID Fogs, Flowmaster 40, VOLANT GEN III CAI, Throttle Body Screen Mod, Custom Painted Relentless RPM Catch Can, UpRev 2 Deg. Timing Advance, Kenwood DNX514 HU, Sony Explode 4ch Amp, Cadence 6.5" Components, (2) 10" Subs, Vshortt Built Custom Box, Clarion APX-1300 400 watt Amp, Black Billet 9" Antenna, Billet Grill , (3) 8" Procomp 130 watt Off-Road Lights, (2) 55 watt Back-up Lights, Custom Painted Engine Cover V with matching CAI lid.
SEMPER FI
WAR EAGLE
[quote name='scottsbro23' timestamp='1302897752' post='160635']
crickets chirping.... Cap'n True Trac? Anyone? Bueller? Bueller?
BruthaDave the True Trac is what you want. It is about $750 or so installed if I remember correctly. You will need some new bearings and other misc items. Look for True Trac on here and you should find a few threads listing all items.
2008 Timberline Green SE Crewcab Longbed 4x4 - One Big Ole Bad Beotch
SOLD.... Now driving a 2011 Kia Sorento AWD
[Image: 90002.png]
[color="#ff0000"]A Veteran - whether active duty, retired, or national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including my life."
It must be a blessing to some that stupidity isn't painful...
[Image: PIC-0011_1-1.jpg]
[quote name='DevilDawg' timestamp='1302900618' post='160636']
$750 for an installed True-Trac is a bit optimistic pricewise but that is pretty close to what the True-Trac diff alone will cost you.
Back a little more than a couple of years ago I had a True-Trac installed and the following link with a pdf file that itemises the needed parts and a tabulation of costs at that time: http://www.titanspot.com/Titan/index.php...t&p=138380
Well I did say IIRC.... I never got one in the 04, and they don't make one for the 08.
[Image: 90002.png]
[quote name='mcginkleschmidt' timestamp='1302890339' post='160626']
http://www.youtube.c...h?v=-5tf65Z0f30
http://www.youtube.c...feature=related
Flat roads is a test?[Image: 017.gif][Image: 018.gif]
Do show part 3 & 4......on a steep incline with a 2wd vehicle on gravel roads pulling a trailer will do.......and throw some snow on too.....[Image: 004.gif]
[quote name='honeykeeper' timestamp='1302916398' post='160642']
Do tell...............and show. You've got the True-Trac, the terrain and snow. Go for it! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
[quote name='mcginkleschmidt' timestamp='1302923092' post='160643']
Do tell...............and show. You've got the True-Trac, the terrain and snow. Go for it! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' /> [/quote]
Check my sig.
I'm back to the new improved OEM rear with E-loc......and the new improved front differential. So far I haven't missed or needed the TruTrac including over 30" of snow this winter.
Guess I'll remove and inspect the TruTrac from the old rear end and scrap it all for projects on the mountain top where I need some steel.....[Image: 009.gif][Image: 003.gif]
I would like to see some vids. of the TruTrac in operation on a steep gravel road...........the ultimate test.....[Image: 001.gif]
or the sideways loss of control on wet or snow covered roads when applying power...makes for fun "drifting"........[Image: 005.gif]
[media]http://www.youtube.com/watch?v=2J4KdQQIzW4[/media]
back on the rocks...........
[media]http://www.youtube.com/watch?v=DjCDuXIQQYc&feature=related[/media]
Now Eaton has an E-locker too....
[media]http://www.youtube.com/watch?v=85-8IozvwVg&feature=related[/media]
Thanks guys I actually spoke to a rep from true trac and am going to go with a limited slip conversion from them. Don't think the locker is what I really need. I don't do any climbing and the only off road I do is at the huntin camp. I do however have to to pull my 23' center console up some pretty steep boat ramps and if I start to spin it will be nice to know the other wheel will grab. Thanks again for the help!
[quote name='BruthaDave' timestamp='1302966329' post='160647']
Awesome glad we could help...
Now to do some research...do they make an Eaton E-Locker for the front of the T??? I got an 08' Pro4x rearend with the E-Locker now...
[Image: 83348.png]
SEMPER FI
WAR EAGLE
#14
No dice for anything newer than 07 still. Neither Eaton, Currie or Richmond Gear ever came through. Oh, sure you can spend upwards of $3grand for a Dana60, but who can afford that? My luck will be at 100,001 miles my diff will pop and I will end up buying an E-Locker like ScottsBro runs. Only way around One Wheel Peel for me.
[Image: 90002.png]
#15
Great vid HK.... love my TT. Effers slippin up the launch ramp while I lmfo..
#16
I do however have to to pull my 23' center console up some pretty steep boat ramps and if I start to spin it will be nice to know the other wheel will grab. Thanks again for the help! [/quote]
Have you tried sand bags in the bed? 3-500 lbs. verses and empty bed makes a huge difference and if you don't use the ramp a lot it will save you some serious money.
