IPDM-ER Failure/Replacement 04-06 Titans
04-06 Titans have an electronic module component that has been prone to early failure:
IPDM-ER is the (Intelligent Power Distribution Module in the Engine Room).
Failure Symptoms: Truck can be stuck in "limp mode", erratic flashing lights such as SLIP, 4WD, ABS, Check engine etc., and most importantly the engine dies and can only be restarted after some time!... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/005.gif' class='bbc_emoticon' alt=':smt005' />
New reports are also showing Titans that won't start up from cold due to a failed IPDM-ER.
Don't look for warning lights or codes to assist you for the diagnosis of a failed IPDM-ER board however there is a "Auto Active Test" feature you can perform easily:
1- Turn the ignition switch on
2- Press the door light activator switch in 10 times........notice the open door light on the dash will flash each time you press the switch.
3- Turn the ignition switch Off then back ON.
4- The horn will beep, oil light will flash, the defroster will cycle, headlights will flash, cooling fan will cycle, wipers will come on and ac compressor will cycle if the IDPM-ER is functioning "NORMAL".
In an Emergency: you may "swap to get you to the shop" the ECM relay & the Fog Lamp relay on the circuit board : but it has been known to only be a very short lived fix.
After the board is lifted up there isn't enough room to lean it back and switch the relays at the bottom with all the wires/plugs in the way so it must come all the way out for a temporary repair.
The OEM warranty on the IPDM-ER is 36 months or 36,000 miles.
Cost of IDPM replacment: Costs from dealers range from ~$180+ to $250 however our vendor Brian at NISSAN PARTS in New Jersey is offering a great price of $92.58 + ship.
Part# for 04-06 Titans is 284B6-ZC00A Be sure to have your Titan year and VIN# for 100% identification when ordering... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/004.gif' class='bbc_emoticon' alt=':smt004' />
NISSAN has addressed this known electrical circuit board component failure and this is "THE" complete upgraded/improved replacement. <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/023.gif' class='bbc_emoticon' alt=':smt023' />
Removal of the IPDM-ER (Intelligent Power Distribution Module in the Engine Room) circuit fuse/relay board.
The job will take about 30 minutes....I know because I did a "test-run".
Seven plugs on the circuit board must carefully be unlocked with a small flat screwdriver and removed, then the board can be removed for switching the relays or total board replacement.
NOTE-1: This isn't a job I would prefer to do on the side of the road or with a hot engine bay as one must lean over the battery or between the battery and the open hood which is very close quarters...but I could do it if I had to.
NOTE-2: I placed a tarp over the battery and just leaned into the job to stay clean.
1- Remove the battery negative cable first then the positive.
2- Remove the IPDM upper black plastic cover then release the two plastic clips on the IDPM and use a small flat screw driver to push the connector locks inward to release and remove each of the seven plugs.
3- After all the plugs are removed lift the board pull out upside down only.
4- Remove the board and insert the replacement board (or make the temporary relay swap) and reconnect the seven plugs and finally the battery cable(s).
Note: A common pliers tool will assist removal of the relays if a temporary repair is to be used.
Test start your Titan and enjoy!.... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/023.gif' class='bbc_emoticon' alt=':smt023' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
For those that need to perform the TEMPORARY relay swap:
(See 2nd picture/diagram below for relays to swap)
Three relays have the same numbers on top: NAIS 4 on the left side and on the right side 40814F 1401 Thailand
On the bottom AGM33201 MO8
The 2nd relay down or the ECM relay has NAIS 5 on the left side and on the right side 40919 1913 Japan
On the bottom ACM33211 MO9
NOTE: This is the only relay made in Japan.
The fourth relay down is the Fog Light Relay.
Pin configurations of all relays are the same and consist of four blades.
You must pay attention to put them back in facing the same direction or they won't plug into the sockets properly so take note when removing.
All four relays on the ECM and Fog Light Relay side of the board face the same direction.
All of the relays on the upper five relay side of the board have a NAIS 4 number like the ECM relay side of the board with four relays.
How's the IPDM-ER circuit board work on my Titan!?! :
ECM (Engine Control Module)
The Engine Control Unit or ECU is a designated computer that was developed to manage the engine control system. The ECM consists of electronics which are mounted on multi-layer circuit board.
The ECM monitors and adjusts the air/fuel mixture and utilizes a catalytic converter to minimize amount of pollution produced from the engine. There are two modes of operation, closed loop, which means the computer has completely taking over the operation system. And open loop which is used when the engine is cold and operates on a preset program. The engine must be at operating temperature before it can go into closed loop.
ECM Engine Control Computer
The ECM monitors the input and output signals produced by various sensors in the system. The ECM then adjusts the system as necessary. Sensors can include: oxygen sensor, coolant sensor, mass air flow sensor, air intake sensor, crankshaft angle sensor, throttle position sensor, camshaft angle sensor and knock sensor. The ECM operating program consists of information cells. These cells hold the code for proper engine operation, if information is out side the cell parameters a MIL (malfunction inductor lamp) or "check engine light".
Once a "check engine" or a "service engine soon" light in your instrument cluster has illuminated the ECM has stored a diagnostic trouble code.
This means the computer system on your vehicle has detected a problem with the various systems it controls. Your car or truck has many different sensors that monitor the various vehicle systems. If the trouble code light has been illuminated your vehicle enters into "limp mode" this means it is running on a predetermined program that causes poor mileage and increased emissions. An engine trouble code reader is an easy to use tool. All 1996 and newer vehicles utilize a "D" style plug-in connector that connects to the code reader. On most vehicles the connector is located at the driver's compartment. Once the code reader is plugged in you can retrieve trouble codes the engine computer has stored in its memory. These codes are the same codes the dealer and repair shops use to replace sensors and clear codes.
The ECM outputs a 5 volt reference to most sensors to drive the monitoring circuits. The ECM also controls the radiator cooling fan, air pump controls, fuel pump, EVAP system and more depending on the vehicle. Communication standards have being established in the OBD2 operating system. Among the communication standards controller area networking or CAN has become very popular and can achieve communication speeds of more than 500 Kbps, which is faster than most communication standards.
Advantages of using buses for communication is that if a fault occurs with any of the process modules, it can be reported separately to a diagnostic tool. Manufacturers have different trouble code faults although some are generic. Wiring is simplified by a technique known as multiplexing. In this kind of wiring system is assigned for each module, which consolidates the output and input for that module.
I hope this helps anyone in need or to save $$$!...... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/004.gif' class='bbc_emoticon' alt=':smt004' /> <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/003.gif' class='bbc_emoticon' alt=':smt003' />
Attached Files Thumbnail(s)
Working on a link now, just added to the site...
Brian
[Image: Bricard-banner-140308.gif]
Here's a clear close-up picture of the IPDM-ER relay/fuse circuit board with the identification/code# label in the lower right corner.
NOTE: The fuses/locations on my 05 IPDM-ER board and the replacement board below are identical......so you should "keep" your old board for parts.....relays too just in case.
If anyone has descriptions/symptoms of IPDM-ER failure please post them. I know ttam......matt has had the classic beginning failure symptoms... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/004.gif' class='bbc_emoticon' alt=':smt003' />
Thanks for the pic. of the updated board Sir Brian... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/006.gif' class='bbc_emoticon' alt=':smt023' />
And here is the link to the New Unit:
http://www.nissanonlineparts.com/storename...l-10476370.aspx
Brian
Looks like my IPDM is on it's way out....not sure what to do.
Got to hotel about an hour ago and when i went to start the truck to move it, it barely started and I had fluttering guages....started fine again but the trip was reset to 0. Let it sit again and it struggled to start but did then the guage flutter again and then normal.
I've got 2 more days to go and not sure what to do....think im gonna do the "swap" and see if it starts fine and all that, then call parts at the nearest dealer in the morning and see if they have the part. If not i'm gonna take the chance and drive the rest of the way on the swap....
Any ideas would be great guys, not too sure what to do.....
[Image: 3302005764_7561a0df67-1.jpg]
Quote from DD:
"Beer and Heavy Machinery are bad...... Rednecks and Sober are bad..... Rednecks with Beer are at work.... All Good"
06 Smoke Crew 4x4 SE w/Big Tow and Popular pkg
MODS:
Performance:
[color="#ff0000"]Magnaflow Single Side S/S Cat Back, Injen Powerflow CAI, True Trac, Mag Hytec diff cover. UPREV Tuned!!
Suspension:
4" PRG Performance pkg. w/ SAW's, Total Chaos UCA's, Deavers and DR rears, 33x12.5x18 Toyo M/T's and PRG street traction bars.
Others:
OEM Fog Lights, 4 Pc Billet from Mr. Grille, Tinted Windows, Active Tuning Grounding Kit.
[/color]
Did you check your battery connections?
yip everything there looks ok....the reset trip kinda threw me off a little...
Quote from DD:
MODS:
Performance:
Suspension:
Others:
[/color]
TitanCanuckLooks like my IPDM is on it's way out....not sure what to do.
I'd go with the SWAP and have Brian send you the upgraded one pronto........anything else I can do to help you PLEASE contact me....good luck! <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/006.gif' class='bbc_emoticon' alt=':smt001' />
That's what I was thinking but the only problem with that is that I have 4 hours to drive tomorrow then ferry ride and 2 hours after that....dunno if the swap will hold up. I know Jody's test lasted for like 3 or 4 days but i dunno what kind of driving they were doing with that truck.
Quote from DD:
MODS:
Performance:
Suspension:
Others:
[/color]
TitanCanuckThat's what I was thinking but the only problem with that is that I have 4 hours to drive tomorrow then ferry ride and 2 hours after that....dunno if the swap will hold up. I know Jody's test lasted for like 3 or 4 days but i dunno what kind of driving they were doing with that truck.
Should hold up long enough........Brians tele. # is 1-800-981-PARTS and the upgraded part # is in the first post 284B6-ZC00A
Bump for the Titan bro in need.... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/004.gif' class='bbc_emoticon' alt=':smt001' />
Looks like all i can do now is swap them out and hope for the best....nearest part is a day away and I cant wait for it.
Quote from DD:
MODS:
Performance:
Suspension:
Others:
[/color]
Son of a B! I gots to order me a back up. Good luck Brad!
#14
TitanCanuckLooks like all i can do now is swap them out and hope for the best....nearest part is a day away and I cant wait for it.
TC be careful when reconnecting the OEM crappy negative cable terminal that it doesn't crack like mine did or go ahead and get the upgraded terminal connector for $2 if you can just to cover that base.
#15
will keep in mind thanks HK and for the luck Kev, I'm gonna need some for sure!
Quote from DD:
MODS:
Performance:
Suspension:
Others:
[/color]
#16
Quote:(KRH2 WROTE) Maybe even an IPDM.. $210 cheap insurance and if you dont use it I am sure on of us would buy it from you... JMO
Stennisyou cant say " THE MAN" didnt warn you..... WOW KEV.... Hey Kevin PM me some Lotto Numbers LOL....
2006 CC LE Galaxy Black- Captians With Rockford Fosgate-Little Tow-High Utility Bed With Util Trac-OEM Chrome Step Tubes-OEM Chrome Bed Rails-APC Bug Deflector-Tint-TomTom 720- Axel Vent Mod-Active Tuning Grounding Kit-HID High, Low, Fogs-LED Interior Lights-I-Pod Interface-Nismo CAI-Flowmaster Super 44 Dual Passenger Side Exit-Super Chips Cortex-LED 3rd Brake Light-Blacked Out Reverse Lighting- PRG MINI LIFT 2.5 Inch Front With 2008 4X4 coilovers, Rough Country Upper Control Arms-Rough Country Sway Bar End Links-1 Inch Rear with C30 Spring Packs-PRG Shackles-PRG Drop Bracket-Bilistien 5100 Shocks-Rear Window Screen-Nitto Terra 325 65 18-Sirius Sportster 5 w/ proclip mount-Wireless Reverse Camera-
[Image: P6120031-1.jpg]
#17
*&&^$&$ it was the battery guys....maybe a little over reaction on my part because of all the recent IPDM failures but i can say one thing, I will be ordering an IPDM from Brian in the morning and having it shipped to my final destination.
Thanks for all the help guys...
Quote from DD:
MODS:
Performance:
Suspension:
Others:
[/color]
#18
TitanCanuck*&&^$&$ it was the battery guys....maybe a little over reaction on my part because of all the recent IPDM failures but i can say one thing, I will be ordering an IPDM from Brian in the morning and having it shipped to my final destination.
Heck..go ahead and order your 35's too...hehe...when you gonna be back in town?? Next saturday (26th) is Laila's (lifted TJ) birthday..and we're taking the TJ and my T to Spring Creek for some wheelin'!! After Joe (bro-inlaw) replace her clutch.
[Image: outrail1-1-1.jpg]
The 2nd Amendment... Washington didn't use his right to free speech to defeat the British, He shot them.
Happiness Is Beating Bama in Anything, Anytime, Anywhere
[Image: 83348.png]
04' Deep Water LE 4x4 CC Off-Road Big Tow, 09' PRO 4X Coilovers & Rear shocks, PRG Mini Kit 2" Front 1" Rear, PRG Adj. Swaybar endlinks, QX56 Swaybar Bushings, PRG Shackles, PRG Off Road Traction Bars, 35" Pro Comp Xtreme A/T's on Graphite OEM 18's, (2012) Pro 4x rear End, Austin E-Lock Mod, Mag Hytec Diff cover, Superchips Cortex, Blue Activetuning Grounding Kit, 6000K HID Lows, Silver Star High & Turns, 3000k DDM HID Fogs, Flowmaster 40, VOLANT GEN III CAI, Throttle Body Screen Mod, Custom Painted Relentless RPM Catch Can, UpRev 2 Deg. Timing Advance, Kenwood DNX514 HU, Sony Explode 4ch Amp, Cadence 6.5" Components, (2) 10" Subs, Vshortt Built Custom Box, Clarion APX-1300 400 watt Amp, Black Billet 9" Antenna, Billet Grill , (3) 8" Procomp 130 watt Off-Road Lights, (2) 55 watt Back-up Lights, Custom Painted Engine Cover V with matching CAI lid.
SEMPER FI
WAR EAGLE
#19
How close was the battery to the end of warranty? That one went fast in its life. Glad you got the Titan running again and one more thing to NOT have to deal with.
#20
Good to hear man! Easy fix! now quit stressing your bride to be!!! LOL
#21
ok ordered the upgraded part so i shouldn't have to worry about this
[Image: titan.jpg]
#22
jhromyok ordered the upgraded part so i shouldn't have to worry about this
Good call and on my list.....after I complete the new downshift button assembly replacement........Wonder if TC ordered his IPDM ?
#23
got the ipdm yesterday, probably will replace over the weekend
[Image: titan.jpg]
#24
jhromygot the ipdm yesterday, probably will replace over the weekend
Good luck and let us know if the instructions need any tweaking..... <img src='http://www.titanspot.com/Titan/public/style_emoticons/<#EMO_DIR#>/001.gif' class='bbc_emoticon' alt=':smt003' />
#25
replaced yesterday...instructions were right on...the plugs are a major pain..esp if you have big hands
[Image: titan.jpg]
