TitanSpot - Nissan Titan Forum: IPDM-ER Failure/Replacement 04-06 Titans - TitanSpot - Nissan Titan Forum
Jump to content
Welcome to TitanSpot - Nissan Titan Forum
Welcome to TitanSpot - Nissan Titan Forum, like most online communities you must register to view or post in our community, but don't worry this is a simple free process that requires minimal information. Take advantage of it immediately, Register Now or Sign In.
  • Start new topics and reply to others
  • Subscribe to topics and forums to get automatic updates
  • Add events to our community calendar
  • Get your own profile and make new friends
  • Customize your experience here
Guest Message © 2010 DevFuse
  • (3 Pages) +
#1 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Post icon  Posted 12 June 2009 - 07:55 AM
04-06 Titans have an electronic module component that has been prone to early failure:
IPDM-ER is the (Intelligent Power Distribution Module in the Engine Room).
Failure Symptoms: Truck can be stuck in "limp mode", erratic flashing lights such as SLIP, 4WD, ABS, Check engine etc., and most importantly the engine dies and can only be restarted after some time!... :smt005
New reports are also showing Titans that won't start up from cold due to a failed IPDM-ER.
Don't look for warning lights or codes to assist you for the diagnosis of a failed IPDM-ER board however there is a "Auto Active Test" feature you can perform easily:
1- Turn the ignition switch on
2- Press the door light activator switch in 10 times........notice the open door light on the dash will flash each time you press the switch.
3- Turn the ignition switch Off then back ON.
4- The horn will beep, oil light will flash, the defroster will cycle, headlights will flash, cooling fan will cycle, wipers will come on and ac compressor will cycle if the IDPM-ER is functioning "NORMAL".
In an Emergency: you may "swap to get you to the shop" the ECM relay & the Fog Lamp relay on the circuit board : but it has been known to only be a very short lived fix.
After the board is lifted up there isn't enough room to lean it back and switch the relays at the bottom with all the wires/plugs in the way so it must come all the way out for a temporary repair.
The OEM warranty on the IPDM-ER is 36 months or 36,000 miles.
Cost of IDPM replacment: Costs from dealers range from ~$180+ to $250 however our vendor Brian at NISSAN PARTS in New Jersey is offering a great price of $92.58 + ship.
Part# for 04-06 Titans is 284B6-ZC00A Be sure to have your Titan year and VIN# for 100% identification when ordering... :smt004
NISSAN has addressed this known electrical circuit board component failure and this is "THE" complete upgraded/improved replacement. :smt023
Removal of the IPDM-ER (Intelligent Power Distribution Module in the Engine Room) circuit fuse/relay board.
The job will take about 30 minutes....I know because I did a "test-run".
Seven plugs on the circuit board must carefully be unlocked with a small flat screwdriver and removed, then the board can be removed for switching the relays or total board replacement.
NOTE-1: This isn't a job I would prefer to do on the side of the road or with a hot engine bay as one must lean over the battery or between the battery and the open hood which is very close quarters...but I could do it if I had to.
NOTE-2: I placed a tarp over the battery and just leaned into the job to stay clean.
1- Remove the battery negative cable first then the positive.
2- Remove the IPDM upper black plastic cover then release the two plastic clips on the IDPM and use a small flat screw driver to push the connector locks inward to release and remove each of the seven plugs.
3- After all the plugs are removed lift the board pull out upside down only.
4- Remove the board and insert the replacement board (or make the temporary relay swap) and reconnect the seven plugs and finally the battery cable(s).
Note: A common pliers tool will assist removal of the relays if a temporary repair is to be used.
Test start your Titan and enjoy!.... :smt023 :-D
For those that need to perform the TEMPORARY relay swap:
(See 2nd picture/diagram below for relays to swap)
Three relays have the same numbers on top: NAIS 4 on the left side and on the right side 40814F 1401 Thailand
On the bottom AGM33201 MO8
The 2nd relay down or the ECM relay has NAIS 5 on the left side and on the right side 40919 1913 Japan
On the bottom ACM33211 MO9
NOTE: This is the only relay made in Japan.
The fourth relay down is the Fog Light Relay.
Pin configurations of all relays are the same and consist of four blades.
You must pay attention to put them back in facing the same direction or they won't plug into the sockets properly so take note when removing.
All four relays on the ECM and Fog Light Relay side of the board face the same direction.
All of the relays on the upper five relay side of the board have a NAIS 4 number like the ECM relay side of the board with four relays.
How's the IPDM-ER circuit board work on my Titan!?! :
ECM (Engine Control Module)
The Engine Control Unit or ECU is a designated computer that was developed to manage the engine control system. The ECM consists of electronics which are mounted on multi-layer circuit board.
The ECM monitors and adjusts the air/fuel mixture and utilizes a catalytic converter to minimize amount of pollution produced from the engine. There are two modes of operation, closed loop, which means the computer has completely taking over the operation system. And open loop which is used when the engine is cold and operates on a preset program. The engine must be at operating temperature before it can go into closed loop.
ECM Engine Control Computer
The ECM monitors the input and output signals produced by various sensors in the system. The ECM then adjusts the system as necessary. Sensors can include: oxygen sensor, coolant sensor, mass air flow sensor, air intake sensor, crankshaft angle sensor, throttle position sensor, camshaft angle sensor and knock sensor. The ECM operating program consists of information cells. These cells hold the code for proper engine operation, if information is out side the cell parameters a MIL (malfunction inductor lamp) or "check engine light".
Once a "check engine" or a "service engine soon" light in your instrument cluster has illuminated the ECM has stored a diagnostic trouble code.
This means the computer system on your vehicle has detected a problem with the various systems it controls. Your car or truck has many different sensors that monitor the various vehicle systems. If the trouble code light has been illuminated your vehicle enters into "limp mode" this means it is running on a predetermined program that causes poor mileage and increased emissions. An engine trouble code reader is an easy to use tool. All 1996 and newer vehicles utilize a "D" style plug-in connector that connects to the code reader. On most vehicles the connector is located at the driver's compartment. Once the code reader is plugged in you can retrieve trouble codes the engine computer has stored in its memory. These codes are the same codes the dealer and repair shops use to replace sensors and clear codes.
The ECM outputs a 5 volt reference to most sensors to drive the monitoring circuits. The ECM also controls the radiator cooling fan, air pump controls, fuel pump, EVAP system and more depending on the vehicle. Communication standards have being established in the OBD2 operating system. Among the communication standards controller area networking or CAN has become very popular and can achieve communication speeds of more than 500 Kbps, which is faster than most communication standards.
Advantages of using buses for communication is that if a fault occurs with any of the process modules, it can be reported separately to a diagnostic tool. Manufacturers have different trouble code faults although some are generic. Wiring is simplified by a technique known as multiplexing. In this kind of wiring system is assigned for each module, which consolidates the output and input for that module.
I hope this helps anyone in need or to save $$$!...... :smt004 :smt003
Attached thumbnail(s)
  • Attached Image
  • Attached Image
  • Attached Image
  • Attached Image
This post has been edited by honeykeeper: 21 August 2009 - 09:41 PM
3-29-05 Born ...4/09/05 Adopted... SEKC... 4 x 4 Off Road with Big Tow and removed E-loc...Blizzard...Graphite/Titanium Interior, Popular Package, Bench Seat.
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, Detroit TrueTrac,
In-Cabin Microfilters, ARE Z shell, OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Burtman Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra 9006 Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, NISSAN I-POD adapter, Bosch Icon Window Wiper Blades, Bosch Ir Fusion Spark Plugs.
Optima Red Top Battery Spicer U-Joints
Amsoil: SEVERE GEAR 75-140W Synthetic in Front & Rear Differentials, ATF Synthetic in Transfer Case.
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
108 year old rebuilt 4,000 lb. road roller/packer. http://www.titanspot...d+Roller+Packer
Posted Image
#2 User is offline   jerseyparts
  • __
  • Icon
  • Group: Supporting Vendor
Posted 12 June 2009 - 09:20 AM
Working on a link now, just added to the site...
Brian
Posted Image
#3 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 12 June 2009 - 09:30 AM
Here's a clear close-up picture of the IPDM-ER relay/fuse circuit board with the identification/code# label in the lower right corner.
NOTE: The fuses/locations on my 05 IPDM-ER board and the replacement board below are identical......so you should "keep" your old board for parts.....relays too just in case.
If anyone has descriptions/symptoms of IPDM-ER failure please post them. I know ttam......matt has had the classic beginning failure symptoms... :smt004
Thanks for the pic. of the updated board Sir Brian... :smt006
  • Attached Image
This post has been edited by honeykeeper: 12 June 2009 - 10:47 AM
Posted Image
#4 User is offline   jerseyparts
  • __
  • Icon
Posted 12 June 2009 - 09:44 AM
And here is the link to the New Unit:
http://www.nissanonl...l-10476370.aspx
Brian
Posted Image
#5 User is offline   TitanCanuck
  • Founder of "TAA" aka Truck Abusers Anonymous
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 02:14 PM
Looks like my IPDM is on it's way out....not sure what to do.
Got to hotel about an hour ago and when i went to start the truck to move it, it barely started and I had fluttering guages....started fine again but the trip was reset to 0. Let it sit again and it struggled to start but did then the guage flutter again and then normal.
I've got 2 more days to go and not sure what to do....think im gonna do the "swap" and see if it starts fine and all that, then call parts at the nearest dealer in the morning and see if they have the part. If not i'm gonna take the chance and drive the rest of the way on the swap....
Any ideas would be great guys, not too sure what to do.....
Posted Image
Quote from DD:
"Beer and Heavy Machinery are bad...... Rednecks and Sober are bad..... Rednecks with Beer are at work.... All Good"
06 Smoke Crew 4x4 SE w/Big Tow and Popular pkg
MODS:
Performance:
Magnaflow Single Side S/S Cat Back, Injen Powerflow CAI, True Trac, Mag Hytec diff cover. UPREV Tuned!!
Suspension:
4" PRG Performance pkg. w/ SAW's, Total Chaos UCA's, Deavers and DR rears, 33x12.5x18 Toyo M/T's and PRG street traction bars.
Others:
OEM Fog Lights, 4 Pc Billet from Mr. Grille, Tinted Windows, Active Tuning Grounding Kit.
#6 User is offline   WhiteNite
  • "First person to get banned from a group buy"
  • Icon
  • Group: Super Moderator
Posted 18 June 2009 - 02:20 PM
Did you check your battery connections?
#7 User is offline   TitanCanuck
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 02:24 PM
yip everything there looks ok....the reset trip kinda threw me off a little...
Posted Image
Quote from DD:
MODS:
Performance:
Suspension:
Others:
#8 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 02:33 PM
I'd go with the SWAP and have Brian send you the upgraded one pronto........anything else I can do to help you PLEASE contact me....good luck! :smt006
This post has been edited by honeykeeper: 18 June 2009 - 02:34 PM
Posted Image
#9 User is offline   TitanCanuck
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 02:36 PM
That's what I was thinking but the only problem with that is that I have 4 hours to drive tomorrow then ferry ride and 2 hours after that....dunno if the swap will hold up. I know Jody's test lasted for like 3 or 4 days but i dunno what kind of driving they were doing with that truck.
Posted Image
Quote from DD:
MODS:
Performance:
Suspension:
Others:
#10 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 02:39 PM
Should hold up long enough........Brians tele. # is 1-800-981-PARTS and the upgraded part # is in the first post 284B6-ZC00A
This post has been edited by honeykeeper: 18 June 2009 - 03:07 PM
Posted Image
#11 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 03:09 PM
Bump for the Titan bro in need.... :smt004
Posted Image
#12 User is offline   TitanCanuck
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 03:18 PM
Looks like all i can do now is swap them out and hope for the best....nearest part is a day away and I cant wait for it.
Posted Image
Quote from DD:
MODS:
Performance:
Suspension:
Others:
#13 User is offline   krh2
  • Capn, Goofball
  • Icon
  • Group: Administrators
Posted 18 June 2009 - 03:28 PM
Son of a B! I gots to order me a back up. Good luck Brad!
My Theme song........... http://www.televisio...ng_Captain.html
Posted Image
#14 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 03:35 PM
TC be careful when reconnecting the OEM crappy negative cable terminal that it doesn't crack like mine did or go ahead and get the upgraded terminal connector for $2 if you can just to cover that base.
This post has been edited by honeykeeper: 18 June 2009 - 03:37 PM
Posted Image
#15 User is offline   TitanCanuck
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 03:40 PM
will keep in mind thanks HK and for the luck Kev, I'm gonna need some for sure!
Posted Image
Quote from DD:
MODS:
Performance:
Suspension:
Others:
#16 User is offline   Stennis
  • __
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 05:42 PM
Quote
(KRH2 WROTE) Maybe even an IPDM.. $210 cheap insurance and if you dont use it I am sure on of us would buy it from you... JMO
View PostStennis, on Jun 18 2009, 06:41 PM, said:
you cant say " THE MAN" didnt warn you..... WOW KEV.... Hey Kevin PM me some Lotto Numbers LOL....
This post has been edited by Stennis: 18 June 2009 - 05:44 PM
2006 CC LE Galaxy Black- Captians With Rockford Fosgate-Little Tow-High Utility Bed With Util Trac-OEM Chrome Step Tubes-OEM Chrome Bed Rails-APC Bug Deflector-Tint-TomTom 720- Axel Vent Mod-Active Tuning Grounding Kit-HID High, Low, Fogs-LED Interior Lights-I-Pod Interface-Nismo CAI-Flowmaster Super 44 Dual Passenger Side Exit-LED 3rd Brake Light-Blacked Out Reverse Lighting- PRG MINI LIFT 2.5 Inch Front, 1 Inch Rear-Rear Window Screen-Cooper ZEON LTZ LT275/70R18-Sirius Sportster 5
Posted Image
#17 User is offline   TitanCanuck
  • Icon
  • View gallery
  • Group: Members
Posted 18 June 2009 - 05:54 PM
*&&^$&$ it was the battery guys....maybe a little over reaction on my part because of all the recent IPDM failures but i can say one thing, I will be ordering an IPDM from Brian in the morning and having it shipped to my final destination.
Thanks for all the help guys...
Posted Image
Quote from DD:
MODS:
Performance:
Suspension:
Others:
#18 User is online   scottsbro23
  • Get Me Some Of Dem Err French Fried Tatters!
  • Icon
Posted 18 June 2009 - 09:45 PM
Heck..go ahead and order your 35's too...hehe...when you gonna be back in town?? Next saturday (26th) is Laila's (lifted TJ) birthday..and we're taking the TJ and my T to Spring Creek for some wheelin'!! After Joe (bro-inlaw) replace her clutch.
My Theme song........... http://www.televisio...rd_And_Son.html Added to sig by Kev...
Posted Image
The 2nd Amendment... Washington didn't use his right to free speech to defeat the British, He shot them.
RIP Bobby Godspeed Brutha
Happiness Is Beating Bama in Anything, Anytime, Anywhere
One of Your Houston Area PRG Suspension Components Installer
04' Deep Water LE 4x4 CC Off-Road Big Tow, 09' PRO 4X Coilovers & Rear shocks, PRG Mini Kit 2" Front 1" Rear, PRG Shackles, PRG Off Road Traction Bars, 35" Toyo M/T's on Graphite OEM 18's, (08) Pro 4x rear End, Blue Activetuning Grounding Kit, 8000K HID Lows, Silver Star High & Turns, Flowmaster 40, VOLANT GEN III CAI, Throttle Body Screen Mod, Custom Painted Relentless RPM Catch Can, UpRev 2 Deg. Timing Advance, JL Audio Cleansweep, Sony Explode 4ch Amp, Cadence 6.5" Components, (2) Kenwood KFC-W2511 10" Subs, Vshortt Built Custom Box, Clarion APX-1300 400 watt Amp, Black Billet 9" Antenna, 4 piece Painted Billet Grill inserts, (2) 8" Procomp 130 watt Off-Road Lights, (2) 55 watt Back-up Lights, Misery-Tom Fog Light Jumper Mod, AVS Smoked Hood Deflector, Bakflip Bed Cover, Custom Painted Engine Cover V with matching CAI lid.
SEMPER FI
WAR EAGLE
#19 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 19 June 2009 - 05:50 AM
How close was the battery to the end of warranty? That one went fast in its life. Glad you got the Titan running again and one more thing to NOT have to deal with.
Posted Image
#20 User is offline   WhiteNite
  • Icon
Posted 19 June 2009 - 07:17 AM
Good to hear man! Easy fix! now quit stressing your bride to be!!! LOL
#21 User is offline   jhromy
  • Spiders and Snakes and 1000 Leggers O MY!
  • Icon
  • Group: Members
Posted 05 July 2009 - 08:52 PM
ok ordered the upgraded part so i shouldn't have to worry about this
Posted Image
#22 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 06 July 2009 - 06:24 AM
Good call and on my list.....after I complete the new downshift button assembly replacement........Wonder if TC ordered his IPDM ?
This post has been edited by honeykeeper: 06 July 2009 - 06:32 AM
Posted Image
#23 User is offline   jhromy
  • Icon
  • Group: Members
Posted 08 July 2009 - 07:25 AM
got the ipdm yesterday, probably will replace over the weekend
Posted Image
#24 User is offline   honeykeeper
  • Sail Naked!!!~
  • Icon
  • View gallery
  • Group: Members
Posted 08 July 2009 - 06:12 PM
Good luck and let us know if the instructions need any tweaking..... :smt001
Posted Image
#25 User is offline   jhromy
  • Icon
  • Group: Members
Posted 13 July 2009 - 06:09 AM
replaced yesterday...instructions were right on...the plugs are a major pain..esp if you have big hands
Posted Image
  • (3 Pages) +
Fast Reply
2 User(s) are reading this topic
0 members, 2 guests, 0 anonymous users
Toggle shoutbox Shoutbox
jdmartin  : (06 February 2010 - 12:02 AM) Yeah I got home fine. OK if you have too many jobs stacked up no problem, we can do it whenever you've got time. Give me a call whenever you're free.
nissan one  : (05 February 2010 - 08:55 PM) is there a ipod integration with the factory nav it has satellite and blue tooth
honeykeeper  : (05 February 2010 - 02:41 PM) how about you?
honeykeeper  : (05 February 2010 - 02:40 PM) The roads are CLOSED here
honeykeeper  : (05 February 2010 - 02:39 PM) I haven't a clue as to how next week will go......I have jobs stacked up high....are you home now?
jdmartin  : (05 February 2010 - 02:22 PM) What about next week?
jdmartin  : (05 February 2010 - 02:22 PM) Tom get that Titan fired up and drive on outta there!
honeykeeper  : (05 February 2010 - 02:12 PM) and any other animals in need
honeykeeper  : (05 February 2010 - 01:20 PM) please feed the birds!
honeykeeper  : (05 February 2010 - 01:19 PM) hi jd.....looks like it might not be until spring...I'm iced in.....~3" deep so far........tree branches are breaking again everywhere....driveway is covered......ahhhhhhh!
inamedhotdog  : (04 February 2010 - 06:40 PM) hey guys, long time no see!!! i guess no old town this year??
BuenasNalgas  : (04 February 2010 - 09:40 AM) How doin everyone?
jdmartin  : (31 January 2010 - 05:41 PM) Tom, what day is good for you this week?
honeykeeper  : (30 January 2010 - 10:49 PM) really?..........did you leave your VISA card # with them?.........if so we need to go for dinner..........the lunch menu is just burgers!~@ lol
balage  : (29 January 2010 - 01:05 PM) Just say: "I know balage from Hungary"...and everything will be free. Just try it! :-D
honeykeeper  : (28 January 2010 - 08:37 PM) SOUPScup bowlBeef Goulash $2.49 $4.29Creamy Hungarian Mushroom $2.49 $4.29
balage  : (28 January 2010 - 02:41 PM) If they are making the "Beef Goulash with Spaetzle " with many red wine, it's bullseye.
balage  : (28 January 2010 - 02:40 PM) Voted! http://www.straighta...63/Default.aspx
jdmartin  : (28 January 2010 - 11:05 AM) Hey Tom that looks good, what day is good for you?
honeykeeper  : (28 January 2010 - 10:54 AM) and the food http://www.straighta...63/Default.aspx
Resize Shouts Area
