Welcome to TitanSpot - Nissan Titan Forum
| Guest Message © 2010 DevFuse | |
Road Packing the HK-Way!!!
Posted 04 November 2005 - 09:43 AM
Had 16.5 tons of "ABCM Crusher Run" or just plain ol...."Road Bond" delivered and spread on my steep driveway this morning. Drove up and down about 6 times......had the E-lok on for the up/down runs and turned it off at the top and bottom turn around areas...12 times on/off..no problems with E-lock for my Titan!!
The E-lock flashes until you move forward slighthly......and the same with turning it off.....it flashes but goes off in a second with a little forward movement.
I totally dismantled the road roller/packer when I got it ( was a gift laying in a field )....it was in sad shape and all the bolts and bearings were shot/loose.
The 6 antique wheels rotate on a solid 3" steel shaft. I replaced all the bolts and had some custom large "end bearings with grease fittings" fabricated/added.
I had the frame on top fabricated/added to hold a water tank. I'm planning on adding the water tank to spread water on the road in front of the roller/packer to wet the ground/road-bond which makes packing/rolling much more effective verses rolling/packing on a dry surface.
It had a long steel tongue with a hole in it to "hitch-up" to but was very hard to align the hole to a tow ball mount and the ball had to be removed from the mount for the bolt to pass through..........so I had the custom hitch assembly fabricated/added also.
I estimate the roller/packer weighs about 4,000 lbs....the water tankfull of water will add more weight increasing the effectiveness of packing/rolling the road.
I am very impressed at how my Titan pulls the roller up the steep driveway..:smt003 ..I left the tires set to the standard 36 PSI while I towed and they never slippped once. I can tow up and down the steep driveway with or without the E-Lock engaged.....no difference....no slipping...my Titan just loves a little pull anytime!! It's really fun to do-it the right way. :smt023 :smt003
Guess I'll have to take a pic. of my 6 x 10' work trailer doing its job next!!
Now for the pics.!!
Peace-Tom :cheers: Highland Beer :cheers:
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, Detroit TrueTrac,
Optima Red Top Battery Spicer U-Joints
Amsoil: SEVERE GEAR 75-140W Synthetic in Front & Rear Differentials, ATF Synthetic in Transfer Case.
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
108 year old rebuilt 4,000 lb. road roller/packer. http://www.titanspot...d+Roller+Packer
Posted 04 November 2005 - 10:01 AM
Posted 04 November 2005 - 10:15 AM
QWIKWHIP said:
I "prefer" to do this once in the fall and once in the spring. This is the first time I re-surfaced the driveway since before last years two hurricanes that caused 18 & 22" of rain each.
If I didn't have such a regiment about doing what I think is "proper maintenance" the road would have been "washed-out" for sure....but since I keep it "tight" and drive easy...4x4 low and in first gear to "engine-brake" downhill and 4x4 hi for driving uphill the cost isn't bad.....this mornings delivery was 16.70 tons of "ABC Crusher Run".....@ $10.65/ton= $177.86 delivered and spread is $65.....Total was $242.86 for the ABC delivered...I think this is very affordable. I put about $1,000 into the cost so far to rebuild the "roller/packer"......It looks like it will last another 100 years so there must be a pay-back somewhere down the road right?? :smt003
Since I'm my own "power company" and "water company".....I might as well be my own "road-repair company"....:smt001 Thanks to my Titan!!
I don't have to do it once a year usually.....I just like to!!:smt003
I love my "Titan-Toys"!!!! :smt001 :smt006 :smt003
Posted 04 November 2005 - 10:59 AM
"I know those little voices in my head aren't real, BUT they've got REALLY good ideas!"
www.flickr.com/photos/danielburkhead/
Posted 04 November 2005 - 11:23 AM
Damn you and your cool toys!!!
Stupid apartments!
Posted 04 November 2005 - 11:34 AM
Her's some pics.......and one with a comparison to my trusty "Highlands Beer-Bottle-Bearing"..:cheers:...
The mountain-gods must be crazy today huh??!!!!! :smt006 :smt003
Posted 04 November 2005 - 11:43 AM
Posted 04 November 2005 - 11:57 AM
Cool, that's not nearly as much as I thought it would cost. :smt003
So Honeyman.... you've become quite the pic poster. :smt004 I'm proud of you. lol :cheers:
Posted 04 November 2005 - 06:41 PM
[/url]
A person will learn, when he has the desire to, and sees how his life will benefit from it. -- Dr. Tom King
Pics from the July 17 TNT-SE Meet!
PRG Leafpacks & Bilsteins
PRG 2.5" Front & 1.5" Rear
SilverStar Highs & Lows
TS Custom Exhaust
ActiveTuning Ground Kit
33"x12.50"x17" Mickey Thompson Baja MTZs mounted on 17"x9" Moto Metal 951s Machined & Black
Posted 04 November 2005 - 06:48 PM
Red, just plain ol' red!
Off Road
Big Tow
Retrax
Westin Bull Bar
Born 03-09-04 Home 12-06-04
~ Tuatha De' Danann ~
An it harm none, do what ye will.
Posted 04 November 2005 - 07:16 PM
Thanks guys.....I have a few more pics. I'll add when I download them. :smt006 :smt003 :cheers:
Posted 05 November 2005 - 04:23 PM
#14
Posted 06 November 2005 - 08:55 PM
[/url]
TS Custom Exhaust
#15
Posted 07 November 2005 - 04:20 AM
Havock said:
My total gravel road length is about 1/2 mile.
Here's some more pics.......how I manually pack small areas....
with a 10 x 10" hand "Tamper".....when this broke which is really strange...I almost put the broken end through my arm!!!!!!
I just dropped it to the ground and it came apart.....white oak. :smt005 :smt003
#16
Posted 07 November 2005 - 05:57 AM
http://www.gasolinealleyantiques.com/celebrity/images/TV/grizzlygarbage.JPG
#17
Posted 07 November 2005 - 08:09 AM
[/url]
TS Custom Exhaust
#18
Posted 07 November 2005 - 06:47 PM
Thanks AUUSN.....Actually I'm more of the tarzan-mountain-gladiator type..although I do restle with bears frequently!!!
that's me in my avatar..... :smt006 :smt003
#20
Posted 07 November 2005 - 07:25 PM
Boot Man said:
Is that your toilet paper?
No it's not on the market yet..I'm still testing it!!!!!! :smt006 :smt003
#22
Posted 07 November 2005 - 09:06 PM
Off Road
Big Tow
Retrax
Westin Bull Bar
#23
Posted 07 November 2005 - 09:26 PM
BigSkiff said:
I'll PM ya about it!!!! :smt006
#24
Posted 07 November 2005 - 11:16 PM
#25
Posted 08 November 2005 - 05:31 AM
BLWedge09 said:
Not a problem.........thanks!!!!!!!......I'll leave it a mystery!!! :smt006 :smt003
Share this topic:
Fast Reply
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Toggle shoutbox Shoutbox
Help
Sign In »
Register Now!
Add Reply
Back to top
MultiQuote
